FUNCTION KEY NOT WORKING PROPERPLY
In  Autocad function key such as f8 f3 etc normally using for shorcuts for some tools  but in my LENOVO its not working as per software, In auto cad F8 function key using for turning on and off an option called ortho ( for turning off/on straight line option) but here when i press f8 its showing volume increase icon.
I enable hotkey in bios & and from device manager > pnp>monitor >enable.but still f8 is for increasing volume in autocad window, i want to use my function key as per software short cuts, please help.....
pendean
Community Legend
Community Legend
Your Lenovo has an override: have you tried contacting Lenovo support?
Which Lenovo model is this?
john.vellek
Hi @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I found this article on mapping Function Keys on a Lenovo. Perhaps this applies to your computer. If not, check Lenovo's site for your model-specific information.
John Vellek
GrantsPirate
Try holding down the fn key and press Esc, that is supposed to toggle the function.  A more permanent solution is to go into the Bios and change the setting for the Function keys back to standard mode.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
