From mechanical to autocad
Are there any way to change a drawing from mechanical to only autocad? I want a drawing only in autocad, completely clearn of properties of mechanical to manipulate and do changes of the drawing in autocad.
Thanks in advance,
Rosa
RobDraw
This can vary depending on your version but you need to export the drawing. If you have mechanical or other vertical, you should be able to export the drawing in a way that will eliminate all things mechanical. If not, then -EXPORTTOAUTOCAD should do the trick for you.
Rob
