From 2D to 3D solids
Hay
I have to hand in sunday my exam from autocad. We had to make a castle in 2D and now we have to make the castle from 2D to 3D with edges and sweep. I want to edge my line but all the other lines go with it. Can someone help me or give me some other options? Thank you!
john.vellek has embedded your image(s) for clarity
imadHabash
Hi and Welcome to AutoCAD Forum,
still we need more information and details for your issue ... but try to use PRESSPULL command and see if it's help .
Imad Habash
john.vellek
Hi @hermien.bulckaenLZ876,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 I agree with Imad that it is a bit tricky to understand what  you are trying to do.
As an example, I made a short video that shows how to sweep a profile (your wall section) along a path (the perimeter of your castle.
Perhaps this will get you started. If not, please add a drawing with your results so far so I can get a better idea of where you are getting stuck.
John Vellek
john.vellek
Hi @Anonymous,
I am checking back to see if my post or Imad's helped you with your problem. Please mark a post or posts as accepted solutions if they resolved the issue or give me a bit more detail on this issue so we can continue to work towards getting this solved.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
