After some time of work on a file, I can no more save. When I click on save or save as, autocad freeze and I have to kill the process. But the duplication file create as a routine each time I save is created. I had this problem on my last 2 files.
I try as a work around to save my work as a block using DWB, when I save I have an error message :
So it seems a problem appeared on a nurb surface after some time of work. I had this problem on complex or simple file.
Do you have a solution ?
Thanks.
Solved by Alfred.NESWADBA. Go to Solution.
I suggest to use PURGE and AUDIT commands and see if it's solved.if not please attache your CAD file here to check it for you.
I forgot to tell I tried Purge, Audit ... without result. And there is no Xref problem.
Herre is one of the file.
Tx.
HI,
would you open attached new CAD file and see if the problem still exist or what.
What makes you sure about that?
When I open your file AutoCAD asks me to recover it, so there are some defects in the file.
Can you start command _ABOUT and show us a screenshot from that dialog. Up to now we don't know which product you are using, which version and which service-pack is active.
- alfred -
Alfred, you have this error message due to the nurb error message, it made a recovery file and it's the one I sent.
About the Xref, I deleted all non reliable to test.
I opened the error file TEST and have same problem, freeze on save...
version "M 49.0" means you don't have any service pack installed, start with updating your product first. >>>click<<<
- alfred -
The update with SP1 solved the problem, I can save now.
Thanks a lot for your time !
