AutoCAD Forum
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
Frame shows when I clip xref in AutoCAD
4 REPLIES 4
jahoffice10
3585 Views, 4 Replies
When I clip my xrefs and create a new boundary, the rectangle shows on screen. The rectangles load in all my other drawings and xrefs. I'm trying to figure how to hide or remove rectangle but still keep xrefs intact. I'm taking an online  AutoCAD coarse and my teacher is away on vacation so any help would be appreciated.
Jeff
@jahoffice10
john.vellek has edited your subject line for clarity: external reference file
4 REPLIES 4
Kent1Cooper
in reply to: jahoffice10
Read about the XCLIPFRAME System Variable.
Kent Cooper, AIA
john.vellek
Hi @jahoffice10,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
 Did you try @Kent1Cooper's suggestion? If so, this should be fixed I think. If not, please explain where you are in the process and possibly share some sample files so I can take a look.
John Vellek
jahoffice10
in reply to: john.vellek
Yes the suggestion did help. He pointed me in the right direction to
navigate the search menu. I found the solution I was looking for.
Thank you
john.vellek
Hi @jahoffice10,
I am glad to hear that it worked. Iā€™ve just accepted the response to your post as a solution so that others can benefit from the information.
In the future, please click on the ā€˜Accept as Solutionā€™ button if/when relevant. Please feel free to let me know if you have any questions or concerns!
John Vellek
ā€Boost
