Announcements
fractional dimensions changing to decimal after printing?
a problem with autocad, fractional dimensions changing to decimal after printing?
Replies (8)
pendean
Community Legend
Community Legend
Never seen that: got a DWG with the problem to share?
I printed DWG drawing to pdf file, and a problem with autocad, fractional dimensions changing to decimal. The dimension in the dwg shows fractional, but the pdf print is showing decimals. (3'-10" becomes 46.0000 or 3'-0" becomes 36.0047) what is happening during printing to cause this change?
Patchy
You already described the problem.
Post your .DWG (It's your autocad Drawing)
pendean
Community Legend
Community Legend
That has never happened here: so show us your DWG file.
undefinedDWG SCREEN CLIP
undefinedPDF CLIP
Dwg file is preparatory not allowed to upload file.
pendean
Community Legend
Community Legend
You need to give us something in a DWG format to test: if you cannot replicate the problem in a new file then INSERT the problem file into a new file and move on. If you can replicate it in a new file, post that otherwise non-proprietary file here.
Pictures do nothing sadly.
The solution was to explode smart dimensions. I'll move on.
M_Hensley
Anyone caught exploding dimensions in our office gets tarred and feathered then carried out on a rail.
Type a product name
