Forced color in a bloc not following when we attach the xref
cyberflow
Advisor Advisor
cyberflow
Hi all,
So we've got a title bloc that has a bloc for a keyplan inside of it.
The colors are forced in that bloc (See right bloc on printscreen)
In this printscreen the left bloc is the one in the xref that is attached, the right one is the copy/pasted bloc.
The forced color isn't following up into the sheet drawing.
Viseretain = 1
Viseretainmode = 0
One thing too, when i create a new drawing it works fine with the bloc at the 23 color (light brown)
Not sure if there's an existing object that conflict or something.
Frank Freitas
CAE/CAD/BIM Coordinator & Support Specialist
LinkedIn
paullimapa
Shouldn’t they both be 0 along with xrefoverride
https://help.autodesk.com/view/ACD/2024/ENU/?guid=GUID-131E3BBB-A28A-40BC-BDC5-A4486C1E2DBE
Paul Li
IT Specialist
@The Office
cyberflow
Well ... i shouldve persue my research before posting the question !
In the layer settings this little setting changes that behavior
And its the : XREFOVERRIDE
Frank Freitas
LinkedIn
cyberflow
@paullimapa Good catch !
Thanx
Frank Freitas
LinkedIn
paullimapa
Looks like you found the solution too…cheers!!!
Paul Li
IT Specialist
@The Office
