I used FLATTEN and now my OSNAPS are not snapping to 'end' etc, though properly selected. It's a fiasco. They are snapping to an 'end' that doesn't exist. Not a zoom in problem and gridsnap is off. The issues is all over, even with simple linework, no blocks. All should be on the same z plane, right? How should I fix this? I'm going insane.
Check OSNAPZ
Restart ACAD
Share your data and we can take a look.
Something basic, not a flatten thing I think
Sebastian
Would you please share with us your CAD dwg file for testing?
Imad Habash
If you LIST a line what coordinates does it show and what do you think they should be based on if you hold the cursor over each end?
Try also AUDIT and/or RECOVER.
Pls come to the forum: https://forums.autodesk.com/t5/autocad-forum/flatten-has-destroyed-my-osnaps/m-p/11615740#M1094167
and use the [Browse] button in your Reply to attach images and DWG files.
Sebastian
