Flatshot operation did not generate any geometry.
Karol-Or
Karol-Or
This error message i received when i tried to FLATSHOT the attached drawing
0 Me gusta
Responder
Soluciones aceptadas (1)
11.934 Vistas
4 Respuestas
Respuestas (4)
imadHabash
Solución aceptada
Hi Karol,
i notice that you're suffering from this 3D model shape.in fact i don't know how did you prepare it BUT the problem exist in splines that make you stuck there.so my advice for you is to redraw this model and extrude it from polyline not any other thing(see attached screen cast) to discover that you can later make FLATSHOT and use OSNAPS.
Good Luck..
Imad Habash
0 Me gusta
Alfred.NESWADBA
my guess: same reason as found out in >>>this thread<<< (double vertices along the spline).
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
ntptorres53
Flatshot operation did not generate any geometry in autocad 2018 but if I open the drawing in autocad 2010 ,no problem making a flatshot, why isnt flatshot  working in autocad 2018, flatshot woks perfect in autocad 2010.
0 Me gusta
Alfred.NESWADBA
I would not say that it's generally not working in 2018.
But to look into this issue to find the reason it would help if you show us the object that does not work for you.
Also please start command _ABOUT and show us a screenshot from that dialog, just to make sure your AutoCAD has all updated installed.
- alfred -
Alfred NESWADBA
0 Me gusta
