Anuncios
Flatshot issues in AutoCAD 2015
No aplicable
To my surprise the FLATSHOT command is no longer working in ACAD 2015. If I try to project a view i«which is in PERSPECTIVE=1 all I get are rubbish results. This used to work flawlessly in 2014 and it became a important part in my workflow. Combining linework with renderings and post-producing in Photoshop. There are a couple of other thread addressing this issue but none was given an acceptable  answer/solution. (VIEWBASE is not an alternative).
I find it deeply disturbing to find a good tool (altough lacking some features) being trashed like this. Any help on the subject would be greatly appreciated.
Thank you
0 Me gusta
Responder
Soluciones aceptadas (1)
10.012 Vistas
22 Respuestas
Respuestas (22)
No aplicable
Hi, got a copy of 2017, it did not fix the issue. copied all the data to new drawing, ex- any flatshot block, and then it worked, then I inserted a few blocks were added into the mix, then it work to a point where one of the blocks failed. The particulars of the block was that it was scaled (inch to metric) and after editing the block allowing it to be 1:1 in model space the flatshot function worked again. Went back to 2015, applied the same routine and the result was the same, resolving my flatshot issue.
0 Me gusta
borrrison007
me pasa el mismo problema
0 Me gusta
Alfred.NESWADBA
What have you tried from the suggestions (and solution) available in this thread?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
0 Me gusta
