Hello @kilshannig
These are constraints applied to the elements. I would suggest to delete them. Use the command "DELCON" and select the entire drawing and press enter to delete all of these constraints applied to the elements 🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
