Find Command Problem
lbellino4
Message 1 of 9
lbellino4
Hello.
When I'm trying to locate specific text in an AutoCAD drawing, I will use the "FIND" command and have never had an issue. But today, it's not working and when I type in the command, what shows is what is in the image attached. How to I fix this to go back to the regular "FIND" command? Thanks in advance.
Using AutoCAD 2022 version.
Replies (8)
Message 2 of 9
Valentin_CAD
@lbellino4 ,
I'm assuming its not showing up when you type it on the command line, and not working from the pulldown.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Message 3 of 9
lbellino4
Correct. I normally type it, but decided to do the drop down per your comment and get an error message as shown in the image attached.
Message 4 of 9
pendean
Community Legend
Community Legend
@lbellino4 from your screenshot, it appears you are accepting a different command instead of FIND.
How are you activating FIND please?
Message 5 of 9
Valentin_CAD
@lbellino4 ,
Emilio Valentin
Message 6 of 9
lbellino4
I typically type "FIND" in the command line. For some reason today, it's not working.
Message 7 of 9
pendean
Community Legend
Community Legend
@lbellino4 Restart your PC right now please.
If that does not fix the problem, then explore this full list of things to do (that get more painful as you down the list) to fix it
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/AutoCAD-Error-Unkn...).
Message 8 of 9
paullimapa
Possibility #1: arx file missing
make sure you have in your acad program folder the following file: textfind.arx
at AutoCAD command line enter this to check:
(findfile"textfind.arx")
If AutoCAD returns nil that means that file has been erased.
It should be found under your autocad program folder like:
"C:\\Program Files\\Autodesk\\AutoCAD 2024\\textfind.arx"
If it is found, then enter the following at the command line to manually load it:
(arxload"textfind.arx")
If load is successful, then the FIND command should work.
Possibility #2: arx file corrupted
If load is unsuccessful, it's possible that file got corrupted. You can try and get a copy of the file from another computer where the FIND command works.
Possibility #3: UNDEFINE
Another possibility is the command got UNDEFINEd
So use the REDEFINE command and enter FIND to bring it back
Paul Li
IT Specialist
@The Office
Message 9 of 9
lbellino4
Your suggestion worked. Didn't think of doing a re-boot of AutoCAD, I'll have to remember that for next time. Thanks.
