Find AutoCAD Serial no
I am unable to open AutoCAD (thats not a problem that i will fix) but I want to find serial no of AutoCAD without opening.
Once i found AutoCAD serial no. is located in a file in computer and I opened that file by Internet explorer but now i forgot that file location.
I trying in google search.
anyone who knows please reply.
Thanks.
nestly2
Finding your Serial Number and Product Key in Accounts
Search or navigate the Windows Registry Editor  (REGEDIT)
HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\Rxx.x\ACAD-xxxx:409\SerialNumber
* Replace "x's" with your version, or state which version you're using for the specific Registry location
braudpat
Hello
With REGEDIT :
HKEY_LOCAL_MACHINE / Software / Autodesk / AutoCAD
R20.1 for 2016 , R20.0 for 2015 , R19.1 for 2014 , R19.0 for 2013 ...
and then look for a Key (REG_SZ) called "SerialNumber" ...
Regards, Patrice (I am not an Autodesk Advisor)
PS: Nestly2 is better than me with its beautiful image !
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
What about newer versions of AutoCAD (higher than 2016)?
I don't know if the problem is network license which I have installed, because I'm seeing xxx-xxxxxxxx in registry entry.
Thanks.
Alfred.NESWADBA
Independent of your release of AutoCAD: try that LISP statement (copy into the command-line, including parentheses):
(getvar "_PKSER")
- alfred -
Alfred NESWADBA
www.ish-solutions.at ... blog.ish-solutions.at ... LinkedIn ... CDay 2025
(not an Autodesk consultant)
It works, thank you very much, but I'm working on software which is reading information from all computers in our company (hardware/software information) and storing them in one place. So we can easily check what we need.
Alfred.NESWADBA
IMHO does not make sense when running a license server because the serial is stored there (on the license server)
- alfred -
Alfred NESWADBA
