Find and Replace with multiple entries?
No aplicable
What I am trying to do is use Find and Replace to search for a couple block attributes at a time. i.e. I can find C4 or 10'-0" but I want to find only instances that contain both attributes. Is this possible?
Thank you.
0 Me gusta
Responder
436 Vistas
6 Respuestas
Respuestas (6)
pendean
Community Legend
Community Legend
Why not use QSELECT or FILTER commands instead if your intent is only to "find only"?
0 Me gusta
No aplicable
Neither of those options will let me drill down to the actual value of the attributes.
Thank you for the suggestion though.
0 Me gusta
pendean
Community Legend
Community Legend
drill down? Post a DWG file and explain please.
0 Me gusta
No aplicable
Okay, attached is the file I am currently checking.
My piece-marks are blocks with attributes used for the data extraction.
Capture1.JPGI am checking this drawing for accuracy and want to find all the (C4)11'-0" occurrences. The mark has attributes for C4 and 11'-0". I can find either but not both. I have an attribute that has fields that pulls all this information into the actual mark (C4)11'-0". That attribute has fields in it and is not searchable.
Capture2.JPG If I run my field to text lisp I can search exactly what I need but then I lose the functionality of the fields in that attribute.
This is why I am trying to figure out a way to search attribute content for both C4 and 11'-0", so I don't have to run the lisp, find and replace then undo back before the lisp. Just trying to streamline the work flow.
0 Me gusta
pendean
Community Legend
Community Legend
Thanks for finally revealing these are FIELD objects and not just "attributes": would have made answering a lot quicker and earlier :cara_con_una_leve_sonrisa:
A field is not static text, so it is not searchable with the built-in tools that simply look for static text. Not sure if there is a solution, but it might be worth taking your last post as written to create a new post in one or more of the Customizations forums over here https://forums.autodesk.com/t5/autocad-customization/ct-p/AutoCADTopic1
0 Me gusta
No aplicable
I was hoping there was a way I could search a couple of the attributes to work around the one with the fields...
0 Me gusta
