Find and Replace Dialog Box issue
Recently my Autocad 2015 Find and Replace Dialog Box does not sort when I click on the desired column. It used to but I do not know why it stopped working. Is there any system variable that controls this feature or is it a bug in AutoCAD 2015.
Appreciate any help as I use this feature in my work.
Thank you in advance.
Alfred.NESWADBA
sorry, I can only confirm that.
AutoCAD 2014 was able to sort the result, 2015, 2016 and 2017 not. At least I have not found a way to get it working.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
john.vellek
Hi @Anonymous,
I tried this in my AutoCAD 2015 and sure enough it DOES work if I click on it a few times. Hmmm...not sure what the magic is here. Can you try it again and see if you click multiple times if it starts to work?
John Vellek
I try to click it multiple times and it still does not work. But the next day, it works fine with one click. Issue has been intermittent with no rhyme or reason. Thanks.
john.vellek
Hi @Anonymous,
I just revisited this today and after a reboot mine worked the first time too!  If you find any action that seems to initiate the lack of sort capability, please add another post.
John Vellek
BIMologist_
@john.vellek
I am running into the same issue as well and I tried it on a different account
There are few posts over the year and no solution as of yet. One mentioned that Adesk support told them that it would be fixed in 2018 hopefully...
https://forums.autodesk.com/t5/autocad-forum/find-window-column-sorting-not-working/m-p/6454293/high...
https://forums.autodesk.com/t5/autocad-forum/find-and-replace-box/m-p/6845757/highlight/true#M865972
Not sure what setting to target ....
Windows 10 Pro Creators Edition.
BIMologist
- Nauman Mysorewala
Did you find this post
helpful? Feel free to like this post.
Did your question get successfully answered? Then click
on the ACCEPT SOLUTION button.
