FIND A TABLES DXE FILE
jackshield
jackshield
CREATED SOME TABLES USING EATTEXT, BUT I NOW NEED TO FIND OUT WHICH FILE IS ASSOCIATED TO TABLE.
HAD THE FORESIGHT TO NAME THE LATTER ONES ACCORDINGLY, BUT NOT SO ON THE FIRST FEW TRIES.
IS THERE A WAY TO IDENTIFY WHICH DXE FILE IS ASSOCIATED TO A GIVEN TABLE?
jackshield
also would like to know if associated file name can be changed?
stevetamplen
Hello jackshield;
Could you upload your files so the community can look at them?
If they are proprietary, I can give you access to a secure area that only I will have access to.
Steve Tamplen
Technical Support Specialist
jackshield
cad file and extraction file
the dxf extension needs to be changed to dxe, it wouldnt allow posting otherwise
