Filtering empty dimensions rebar range dimensions exisiting drawings
krishnandynBQY9Z
krishnandynBQY9Z
Dear All,
Please help me in filtering out empty dimensions rebar range dimensions to remove to mark some other thing in the same sketch.
Krishnan
imadHabash
You can select them by SELECTSIMILAR command. Click on below image to see how it works.
Imad Habash
Kent1Cooper
If you mean those Dimensions that show no text, they have a space as override text content.  Put this in at the Commmand: line to select/grip/highlight them:
(sssetfirst nil (ssget "_X" '((0 . "DIMENSION") (1 . " "))))
Kent Cooper, AIA
Kent1Cooper
@imadHabash wrote:
.... SELECTSIMILAR command. ....
What are your SelectSimilar Settings?  When I do that, it finds all the Dimensions, not just the empty ones.  I don't see a choice for text content in the Settings, but maybe that's in newer versions [Acad2020 here].  And in your video, it finds one that is not empty [the short one with just a decimal point content].
But QSELECT can also be used to find Dimensions with a Text override of " " [a space].
Kent Cooper, AIA
