FILTER command to select MTEXT objects based on contents
I am using AutoCAD 2015 and I have a drawing with multiple MTEXT objects which are diffuser/grille references ie. SG1, SG2, EG1, B/SG1, B/EG1
What I would like to do is use the FILTER command to select all MTEXT items that contain the text SG and EG but I can't for the life of me figure out how to do it.
Can anyone help? Any help would be greatly appreciated.
h_s_walker
I would do a quick select.
QSELECT
Change the object type to MTEXT
Now select CONTENTS
Change = to WILDCARD MATCH
Now put *?G#* in the white box
The ? is a single letter before the G
The # is a single digit after the G
The *s at the beginning and end are Any characters at the beginning and end (including no characters at all)
You can ignore the question mark if you want
Howard Walker
Left Handed and Proud
3wood
QSELECT
Agree.
Settings as below:
sbutler502
Does not work for me (Civil 3D 2022).
Looking to just select three digit numbers.
wild card filter ### gives nothing
wild card filter *** gives everything
wild card filter ??? gives nothing
The hidden formatting codes are causing it to fail.  All the numbers are preceded with
\pxqc;
Almost as bad as drawing on layer 0.
Patchy
Use text value
*SG*
it will work
sbutler502
Nope first I have to strip out some formatting.
I'm trying this
StripMtext Version 5.0b (Removes embedded Mtext formatting)
With the amount of annotative mtext it took awhile.
Wildcard ### now works.
Patchy
Post your .dwg and see if it works.
