Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
I am trying to write with the romanc.shx font, but it is hollow. Is there a way to fill in the text?
If there is not, I would like to switch to ROMANC.ttf, yet this font is not available on AutoCAD, despite being installed on my computer. I read on another post that AutoCAD automatically uses the shx version of a font. Is there a way to access/switch to the ttf version?
Thanks, Rob
Solved by Patchy. Go to Solution.
Make sure that the font you want to use is in the correct folder, e.g. C:\program files\autodesk\autocad 2015\fonts.
You can't "fill" shx fonts.
