Fillet Polyline - False direction
erhan.lale
erhan.lale
I have a Polyline based on 2 vertical arcs and 2 prependicular lines.
I send command
Fillet -> Polyline -> Radius 10
and select object. You can see the issue clearly: bottom left and bottom right corners are well done but top left and top right fillets are on false direction. I can explode and make fillet of 2 lines; but I want to know, why it is happening because I am try to automate some jobs.  fillet-problem.png
AVCPlugins
You might find AVC Fillet plugin helpful. The FP command works much better than the built-in counterpart.
Plugins for AutoCAD
A>V>C>
AppStore | Facebook | Twitter | YouTube | Blog
Valentin_CAD
@erhan.lale ,
You must select on the lower side of the lines (the side ones) - weird, but it works.
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
erhan.lale
Fillet 2 lines works like you described.
But I do it with polyline and all 4 corners with one fillet.
It can not a be a random result. It must be a reason... 🤔
Valentin_CAD
@erhan.lale ,
Emilio Valentin
