Fillet line with polyline
Hello everybody.
I'm trying to fillet a polyline having a certain thickness with a line (Autocad 2016 and 2019). I select the polyline first and then the line, but I get a non-uniform fillet, as can be seen from the image:
I want, however, to obtain a uniform result, as shown in the image below:
I have been working for 20 years and have never stumbled upon such a hostile problem. Do you know how I solve? thank you
ВeekeeCZ
Nothing you can do but fix it manually.
Go to the properties palette and reset a global width.
Really? In autocad 2010 i can do it ...
ВeekeeCZ
The thing is that FILLET has changed. Probably in 2014 or so.
If you're not using LT, you can still run the old version using a LISP expression (LISP in general uses old versions of commands). Copy-paste it into the command-line as it is.
(command-s "fillet")
thanks.
