files to the project, the images are not uploaded How to fix?
Message 1 of 12
Hello! After uploading files to the project, the images are not uploaded after saving the project? How to fix?
Replies (11)
Message 2 of 12
cadffm
what does it mean?
"After uploading files to the project"
"the images are not uploaded after saving the project? "
What product are you using?
AutoCAD don't have "projects"!?
What ever you do with your DWG, make sure Autocad is still able to find the linked external files..
Where was the dwg saved(which path)
Where is it now (which path)?
Where was the location of your images(which path)
And what path you saved in your external reference manager (command XREF, property "saved path for each image)
Sebastian
Message 3 of 12
I execute the project, I loaded files, after saving they are not loaded, pictures are not visible
How to make the right path for them?
Or what to do to fix it?
Message 4 of 12
cadffm
How to fix?
First we have to find the problem, then we can find a fix.
1. A good way is to answer my questions 😉
And show us a screenshot of your xref palette while you selected a row of one missing jpeg
Or ... post your question here
https://forums.autodesk.com/t5/russkiy/ct-p/5056
Translation from russkiy to english and from german (me) to english is not the best way to discuss
Sebastian
Message 5 of 12
pendean
Community Legend
Community Legend
@Anonymous Do you mean you loaded images into AutoCAD and they are now no longer visible?
then read this https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Embedded-TIFF-and-PDF-images-disappear.html
What Language is this (see below)? always feel free to type in your native language if this is not the correct guess from my side https://forums.autodesk.com/t5/russkiy/ct-p/5056
Message 7 of 12
I'm using AutoCAD 2021
“AutoCAD is still able to find the linked external files” How I can do it?
How do I set up the correct path for my files?
Message 8 of 12
pendean
Community Legend
Community Legend
Message 9 of 12
Very grateful, I figured it out!)
Message 10 of 12
Message 11 of 12
ennujozlagam
Message 12 of 12
ennujozlagam
you can try something like this?
