File wont flatten, certain lines still of 0 on Z axis
24782459
Observer
24782459
Observer
Observer
Hi all,
I have received a file which needs to be flattened due to someone was not working in 2D. I have went through all the channels of flatten cmd, QSELECT, change properties and so on but I'm still finding lineS and arcs that aren't on z axis 0. Any help on this?
AUTOCAD 2025 - WINDOWS
pendean
Community Legend
Community Legend
Expand the commandline to 5-10-20 line tall, or invoke CTRL+F2, scroll up or down to see what errors and other issues FLATTEN command reported as it was running, there is often a clue there.
OR... Share your DWG file with the issue here.
Observer
Observer
Thanks for the response. I have attached the dwgs. Doc 1 is where I've ran through the steps I mentioned above, when flattening this error showed 'function undefined for argument: -1.53627e-12'. Doc 2 is the original document which also needs flattening. Any help would be greatly appreciated
imadHabash
Try to use some command under title  To flatten a drawing using LISPs, macros, and scripts  in this link.
Imad Habash
