File Type Association - Win 10
No aplicable
Any .dwg file I have wants to open with AutoCAD Mechanical.  If I try to change the file type association, the only apps it shows as available options are "AutoCAD Application" and it does not let me specify which application to use (MEP, Mechanical, AutoCAD, etc.).  First question is how to I change it so any .dwg opens with AutoCAD?  Second question, is there something that distinguishes an MEP or MECH file from an standard AutoCAD file and if so, can I tell it to open MEP files with MEP, MECH files with MECH, etc.?
Responder
Soluciones aceptadas (1)
502 Vistas
1 Respuesta
Respuesta (1)
rushabhthakkar_910
Solución aceptada
hi,
The Solution can be viewed here...
Still, I have Copied it below for reference.....not solved by me.....
I suggest to try from Control Panel\Programs\Default Programs\Set Associations  . This settings page allows you to set the default program for every known filetype.
Thanks and Regards,
Rushabh Thakkar.
Please use the Accept Solution button to mark any posts that provide the answer or solution.
Likes are always welcome.
LinkedIn | Instagram | Facebook.
