FILE SIZE TOO BIG !
FILE SIZE TOO BIG !
No aplicable
Hello
i cant get my file size down below 8000kb even with just 1 point, im even saving file that are 100kb and saving them and they are increasing to 8000kb
please advise
0 Me gusta
Responder
2.675 Vistas
24 Respuestas
Respuestas (24)
imadHabash
I suggest to try :
  1. Enter the -PURGE command and choose Regapps >> * >> N >> then save .
  2. Enter the PURGE command and select all options.
  3. Enter the -SCALELISTEDIT command and reset the scale list.
  4. Enter the FILTERS command and delete layer filters.
Imad Habash
0 Me gusta
Valentin-WSP
@Anonymous ,
Welcome to the forum.
Consider the suggestions in this link:
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
0 Me gusta
No aplicable
Hello
This hasn't worked, is there another way what is the reason i never had
this problem on 2018
Im reverting back to old drawings which were 100kb and saving them and they
are enlarging to 7500kb
Regards
Dean willetts
0 Me gusta
imadHabash
Can we have some of those drawings please .. for testing ?
Imad Habash
0 Me gusta
No aplicable
hello
attached dxf
0 Me gusta
imadHabash
Nothing attached !!
Imad Habash
0 Me gusta
No aplicable
hello
there should been, resent
0 Me gusta
cadffm
0 Me gusta
No aplicable
hello
0 Me gusta
No aplicable
attach dxf
0 Me gusta
cadffm
Which program in use, AutoCAD or AutoCAD LT?
then use command
-EXPORTTOAUTOCAD
to create a new clean file
This is a file contain a lot of CIVIL3D stuff, what you can not use in AutoCAD
and if nobody else need the Civil3D data in your file, then use -ExportToAutoCAD.
Sebastian
0 Me gusta
imadHabash
I open your CAD dxf file then _purge ( Regapps ) >> save it as .dwg file .. when i convert it for .dwg file , the size reduced to 1.18MB . But when i make save as to dxf file it come back big file. The DWG file format is a compressed format, while DXF files are an ASCII text format. These files will always be larger than the originating DWG.
Imad Habash
0 Me gusta
No aplicable
Autocad lt
0 Me gusta
No aplicable
thats never been a problem before, like i said i can save 1 point into a
dxf file and it be 7500k
i have never had these problems on previous autocads
0 Me gusta
jrreid
Funny about file sizes and saving. I started a new drawing, purged all out... saved and file size was 349.
Save 2nd time and it went to 504, saved 3rd time and stayed at 504.
Took your DXF file that was 769. Saved as -1 and file size was 262... did a 2nd save and file went to 405.
Ran OVERKILL... there was 110 over laid lines.. and did save as -1A.. file went down to 261. did a 2nd save and file went up to 392.....
Ran some other tests... Zoomed way in save file went up. Zoomed way out file went down...
Not going to help anyone but just thought I'd have some fun in sharing.
JRR.
0 Me gusta
cadffm
@jrreid everything explainable and no mystery
Sebastian
0 Me gusta
No aplicable
How do you explain 1 point being 7550kb
0 Me gusta
RobDraw
There is content stored in those files from C3D making them bloated.
How do you explain that?
Rob
0 Me gusta
No aplicable
Thats not my point, im saving files i saved previously on autocad 2018
which is 200kb and saving the same file on autocad 2022 and it saves at
7500kb there is surely a glitch in 2022
0 Me gusta
