File Open Dialog Box properties
When I had AutoCAD 2021 and earlier releases I would go to the 'start' tab and pick 'Open' and the Select File dialog box would pop up (as it should). I would then navigate to a dwg file and right-click, then select Properties and then check or uncheck the 'read only' attribute box as required.
In AutoCAD 2022 and 2023 if I try to do the same operation, the Properties dialog doesn't appear, instead I get an error message: "The properties for this item are not available." See screenshot below.
I have 2022 installed on another identical PC and it does not have this problem.
Any ideas?
