04:08 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Hello. We are having some trouble since we updated to Autocad 2017 at work.
Sometimes we open a file with full rights for edition and if a workmate opens the same file later, the "DWG file is currently in use or is read-only" doesn't show up. The 2nd user will work normally and save the file without any problem. However, the first user, after trying to save the file, receives an error message which doesn't allow saving it.
This leads to a process of merging the work of the two of them, which causes a lot of problems. We have to be very careful if we don't want to lose any information.
I'd really appreciate some help with this issue.
Thank you!
Joaquin
Link copied
