File corrupt and not functioning when switched view
alyssapipolo1
Community Visitor
alyssapipolo1
Community Visitor
Community Visitor
I have a file that I have be working on solely in 2d wireframe view. I copied a block which I downloaded as a dwg and copyedclip into my file it was distorted into a different perspective from the original. My solution to this was to change my viewport to 3d, shaded view, which I now realize was a huge mistake. When opening the file it is now frozen and not functioning to switch the original viewport properties. I have been unable to recovery the previous version of the file.  If there is anyway to fix this issue or reverse the switch please let me know! Thank you in advance.
0 Me gusta
Responder
168 Vistas
2 Respuestas
Respuestas (2)
paullimapa
are you able to insert the problem dwg into a new drawing and then explode it?
Paul Li
IT Specialist
@The Office
0 Me gusta
pendean
Community Legend
Community Legend
How to fix files https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
Or you can share it here for others to try if you wish.
0 Me gusta
