Field values contain xref name
TomHia
TomHia
AutoCAD 2021.
I think it's related to general setting rather than dynamic blocks.
I've created dynamic blocks in a file which is xrefed in the main drawing. Those blocks contain an attribute with a field pulling out the blocks' names. I've tried to set the fields using both the NamedObject and BlockPlaceholder fields and the result is the same.
The issue: attributes with name fields containing blocks name show the xref name together with the block's name. If I unload and then reload the xref its name is gone and it looks fine but still always prints with the block's name. Regenerating the file brings xref's name back.
What is expected:
What is shown in the main file:
What could be an issue?
Best regards,
Tom
cadffm
the blockreference you are talkling about is inside the xref file, not in the main file?
If so, xrename|blockname is the real blockname (in your main file) and the field works as designed.
Sebastian
TomHia
Yes, those blocks reside in the xrefed file.
That's....sad.
Thanks for clarification.
