Starting in December, we will archive content from the community that is 10 years and older. This FAQ provides more information.
AutoCAD Forum
Field Value Based on a Block Location
2 REPLIES 2
dave
267 Views, 2 Replies
I am not sure if this is possible but I figured I would give it a try.
I will start out by explaining my situation.
I am in Landscape construction and I am trying to link surfacing key (shows which page that surface detail can be found on) to the page number the detail can be found on.
For example I have SOD in my layout page. I have a call out leader that shows it is  1/DT.1   meaning it is detail 1 on page DT.1   Is there a way to have the call out leader automatically put in 1 / DT.1 when I insert my sod detail in slot 1 of DT.1?
2 REPLIES 2
john.vellek
in reply to: dave
Hi @dave,
I see this question from time to time but I am not sure that I really have a ready answer.  Can you provide a sample of how you are working?  Do you use sheetsets with Callout blocks?
John Vellek
dave
in reply to: john.vellek
I don't have a specific sample yet, I am re-building our technical process now and though of this as an idea.
Once I start to flush it out more I can post sample. I was just curious if this is something that is out there in the AutoCAD world before I started my process.
I currently do not use Callouts. I will look into those. Thanks
AutoCAD Inside the Factory
