Field create file date does not change?!
No aplicable
I created a 'creat date field' in a block attribute. But whenever I copy a dwg file to a new copy, it did not change anything. I tried a few other pc and it still worked. So I don't know how should I do now. Please help!
0 Me gusta
Responder
1.141 Vistas
12 Respuestas
Respuestas (12)
ara_neresesian
hi
if in other pc it is working good check your system var it must be 31 if not set it  <<fieldval>>value   to 31 press ok
and regen your drawing ,when you down it must be ok
anyway send your original file which you made your first field dwg. I have to check your file
0 Me gusta
No aplicable
Thanks Mr. Ara, but I've tried some solutions in forum and it didn't work, include yours. This is my file.
Thanks in advance!
0 Me gusta
ara_neresesian
hi
the date field is depend to your pc time .
check  your pc date is it changes ?
in your file which I opened a few second ago it was 2017-03-28
try to change your pc date and regen your dwg file it must change .
if not inform me please  I am searching to find problem
0 Me gusta
No aplicable
I've checked and everything is ok. My date form on PC is dd-MMM-yy. Probably the problem is my setting or smt in CAD, not my file.
0 Me gusta
imadHabash
>> But whenever I copy a dwg file to a new copy, it did not change anything. <<
i notice that your DATE text field linked with CreateDate field names.this date will be modified to the date which your CAD file was created on not to the date in your moment day.so you have to edit your field to Date field name as attached below image.
Imad Habash
0 Me gusta
ara_neresesian
try to use diesel text,  watch this video
https://youtu.be/YqB4XmEzeys
and see the result
0 Me gusta
cadwomen
 watch this video
morning.
got a 404 Error ?
cu cw
If my post answers your question, please mark it as an Accepted Solution, so that others can find answers quickly!
0 Me gusta
No aplicable
I need the create date field because I copy to the new file everyday and work on it, previous files are just for backing up. Whenever I want to see old files, I can control the by the time it was created.
0 Me gusta
No aplicable
The problem is, why does others PCs still work with my file, but my PC. Sorry it takes too long for replying, I was too busy. Thanks everyone.
0 Me gusta
john.vellek
HI @Anonymous,
I see that you are visiting as a new member. Welcome to the Autodesk Community!
I tested your file and it seems to work fine on my side too. Please tell me, if you add a field in your drawing (not in a block) and set it to a date with a time in the format, if you use UPDATEFIELD after a couple of minutes does it update to show the new time?  If this does not work and your fieldeval=31 then I suggest that you perform a Reset Settings to Default to see if that corrects the issue for you.
John Vellek
0 Me gusta
No aplicable
never mind ...
0 Me gusta
john.vellek
Hi @Anonymous,
I am checking back to see if my post or others helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
0 Me gusta
