Field Conversation Factor-Default Setting
Hello everyone,
I'm using cm on my projects, and entering the area info with m². I think field command is very useful, but I don't want to change conversation factor each time while using it.
Is there any way to change default conversation factor to 0.0001 or can I add format to the default format list which will divide my result to 10000?
I search internet and this forum but I cannot find anything about it.
Thanks in advance...
Sorry for my bad spelling it should be written as Field Conversion Factor
TheCADnoob
The closest i could come with out checking into lisps is copying the filed and using formula to set the mimic additional formatting as opposed to using the additional formatting dialog.
So you can basically copy your mtext field and click edit fleld and just reselect your object and the rest of the formula is in place.
CADnoob
Thanks  TheCADnoob, I think there is not any other solution for my question. Thanks for your time Smiley Wink
