Fence Layout
Fence Layout
Fence Layout
How is this done in CAD? Im still new to CAD and working with fence installation . How is this done, Please see image attach.  Im trying to indicated where and how far apart each post is going to be.layout.jpg
pendean
Community Legend
Community Legend
Are you taking classes by chance? hope so, this is not the place to learn the basics.
Here are topics to cover your loaded questions:
Copying: https://tutorial45.com/autocad-tutorial-12-move-and-copy-objects-in-autocad/
Alternate to copying to get the spacing https://tutorial45.com/autocad-tutorial-10-arrays-in-autocad/
Dimensioning https://www.dummies.com/programming/autocad/how-to-add-dimensions-to-a-drawing-in-autocad-2014/
GrantsPirate
You would use array command to place the posts.  Showing every 10' dimension is a waste of time, call it out below the overall dim, much like they did for the shorter fence.  Give dims to the 4' gate post.  Use the dimension  tools to add dimensions.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
tboehler
Our fence design details vary greatly depending on the client and type of project.  From a note saying "Fence this area" to a set of detailed designs.
In general I will give coordinates for each corner post or post that changes bearing, and maybe gates.  Dimensioning the space between posts once or twice as typical, dimension all gates, dimension any non-typical lengths, distances (offsets) from important features.  Bearing and distance of the fence alignment is sometimes asked for (or add a dimension of each straight segment).
We also supply details (elevation views) either drawn by us or from the manufacturer.  That have complete details on the construction of the fence.
thank you so much.
