Fatal error
Fatal error
Fatal error
When i open autocad i find "fatal error unhandled e06d7363h exception at fcffa49dh"
And
I find getting an error window of explorer.exe with message server execution failed , when i right click on desktop properties and select either screen resolution or personalize option
try open autocad this way Right-click the AutoCAD product icon on either the desktop or the Start menu and click Properties. In the Properties dialog box, click the Shortcut tab. In the Target field, edit the content to have the /nohardware switch at the end. For example: "C:\Program Files\AutoCAD 2015\acad.exe" /nohardware Click OK. Double-click the modified icon to launch AutoCAD. Once the program has launched successfully, undo the prior setting changes that were made (refer to product Help for information about configuring performance settings).
Grover_Puma
Here you will find more information about it. Thank you
https://forums.autodesk.com/t5/forums/searchpage/tab/message?advanced=false&allow_punctuation=false&...
ACEPTA LA SOLUCION que responde a tu pregunta, esto ayudará a otros a encontrar respuestas de una manera mas sencilla.
Si te gusta esta publicación, dale ME GUSTA.
Saludos!
