Fatal Error
Fatal Error
Message 1 of 8
Fatal Error
most of the time this error "FATAL ERROR: Unhandled Access Violation Reading 0x25e8 Exception at 3259aa38h" shown in the screen, and after that AutoCAD shutdown automatically and I lost all the unsaved work too. can any one please help me.
Replies (7)
Message 2 of 8
Slawomir_
Hi kalam.fahad and welcome at forums.autodesk,
quick question: are you working on AutoCAD or on some derivative soft built on AutoCAD?
Message 3 of 8
working on AutocCAD Design Suite 2014 CAD Worx
Message 4 of 8
Alfred.NESWADBA
Does AutoCAD also crash when you use an AutoCAD profile which does not load CADWorx?
Can you start command _ABOUT and show us the screeshot from that dialog?
Also please let us know
  • which graphic card and driver you are using (command _GRAPHICSCONFIG ==> screenshot)
  • if the crashes also happen when you have hardware acceleration off (same command: _GRAPHICSCONFIG)
  • how often does AutoCAD crash and does it crash only on some specific drawings
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 5 of 8
Slawomir_
CADWorx is causing problems. Perhaps Service Pack for CADWorx will solve this problem? Look on the web latest official and compare your version (check it using CADWORXABOUT command).
Message 6 of 8
imadHabash
Hi and Welcome to AutoDesk Forum,
I suggest to do the follow on the CAD file that always Fatal error appeared:
  • Command Audit .
  • Command Purge ( Regapps ).
Command: -PU -PURGE
Enter type of unused objects to purge [Blocks/DEtailviewstyles/Dimstyles/Groups/LAyers/LTypes/MAterials/MUltileaderstyles/Plotstyles/SHapes/textSTyles/Mlinestyles/SEctionviewstyles/Tablestyles/Visualstyles/Regapps/Zero-length geometry/Empty text objects/Orphaned data/All]:r
also be sure that these boxe in purge dialog are selected (see below image)
the previous procedures must be always be done even to the attached xref files (if any).
Imad Habash
Message 7 of 8
Slawomir_
Have you found answer in this topic or you need further assistance? Just asking.
Message 8 of 8
i don't know that is that the solution but i just update the Graphic card
driver, so the error is not come again
