Fatal error when using SAVEAS or PLOT command in AutoCAD 2016
When i go to use the SAVEAS option..a pop up comes showing FATAL ERROR
and when i use the PLOT option it shows same FATAL ERROR 'unhandled e0434352h Exception at 831fa388h'- in both saveas and plot commands..and in both cases the cad file closes.
@Anonymous
Topic Title has been changed by @Tiana_Y for better findability Original: Fatal error shows in Autocad 2016when i go to save a file or use the PLOT option
amdesoky87
Hello sir,
First search for any update available for your Autocad version.
Second if to don not find I advise you to reinstall the software, it just my opinion
pendean
Community Legend
Community Legend
AutoCAD2016 is not new: so is the problem with one or a few files, or did something change with your very old setup or PC or where you store files today?
or do you just need to fix your DWG files https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCA...
Tiana_Y
Hi @Anonymous
Welcome to the Autodesk Community, and thank you for posting your question here in the AutoCAD forum! I am just checking in to see if you need some more help with this issue or if the suggestions that @amdesoky87 and @pendean made helped resolve the issue.
If one or more of these posts helped answer your question, please click Accept as Solution on the posts that helped you so others in the community can find them easily.
Tiana.D
Community Program Manager
Contact Autodesk Support
