Fatal error when attaching a recap file
carolinaP8MJ3
carolinaP8MJ3
Hi, I have an *RCP file 3kb, when operating the command "pointcloudattach" a fatal error pops up and autocad crashes.
my computer has:  Intel(R) Core(TM) i7-6700 CPU @ 3.40GHz 3.41 GHz processor, 16 gb RAM , window 10 pro. Any idea what the problem could be?
Many thanks
0 Me gusta
Responder
884 Vistas
21 Respuestas
Respuestas (21)
paullimapa
In AutoCAD enter About command, do a screenshot and post that in your reply
Paul Li
IT Specialist
@The Office
0 Me gusta
carolinaP8MJ3
ā€ƒ
0 Me gusta
carolinaP8MJ3
I hope it helps :manos_unidas_para_la_oración: thanks!
0 Me gusta
paullimapa
You misunderstood my reply.
In AutoCAD at the command prompt enter command: ABOUT
Do a screenshot of that window and post that here
Paul Li
IT Specialist
@The Office
0 Me gusta
carolinaP8MJ3
this is the screenshot after typing ā€œaboutā€ is that what do you need?
ā€ƒ
0 Me gusta
paullimapa
Download install 2025.1 update
Paul Li
IT Specialist
@The Office
0 Me gusta
carolinaP8MJ3
Hi, it’s a trial version that I installed today from the website, so ai am not sure if I can update it?
0 Me gusta
pendean
Community Legend
Community Legend
You are missing the 2025.1.1 update: get it now, restart your PC after it is done installing. See if that helps.
Also share a screenshot of your GRAPHICSCONFIG command pop-up from inside your AutoCAD 2025 too please.
0 Me gusta
carolinaP8MJ3
ā€ƒ
ā€ƒ
0 Me gusta
carolinaP8MJ3
hi,
How can I get access to the updated version is I am using a trial? Thanks for your replies
0 Me gusta
Valentin-WSP
@carolinaP8MJ3 ,
Check your Windows 10 version is version 1809 or above, in addition to the other requirements.
Please select the "Accept as Solution" button if my post solves your issue or answers your question.
Emilio Valentin
0 Me gusta
pendean
Community Legend
Community Legend
hi,
Trial versions have no access to any updates.
Change to something else at #1 or turn off at #2
0 Me gusta
carolinaP8MJ3
thanks for replying… I tried all of them, nothing worked… I still have the ā€œfatal errorā€ message:(
0 Me gusta
Valentin-WSP
@carolinaP8MJ3 ,
Update the .NET Framework to a more current version.
Emilio Valentin
TheCADnoob
Does your recap file open in recap ok?
3K seems small to me, though I generally work with larger recap sets.
CADnoob
0 Me gusta
carolinaP8MJ3
yes in recap I can see it/ open it. Using recap I tried first just ā€œsaveā€ command and it’s the 3K file. When I use the export command the file is huge but with both examples Cad crashes… so I don’t know…
0 Me gusta
TheCADnoob
Is the rcp on a network or on the local PC?
CADnoob
0 Me gusta
carolinaP8MJ3
in a network and the trial versions (autocad and recap) in my computer
0 Me gusta
carolinaP8MJ3
I mean: both software in their trial versions are installed in my computer but when i save the file I save it in our network
0 Me gusta
