>> it happens when I try to close the program(AutoCad 2016)
So this error appears after all drawings are closed, but before AutoCAD itself is closed?
In that case I guess you have tools/applications installed on top of AutoCAD, is that correct?
>> My Materials Browser (2016) crashes
Please show a screenshot where exactly you click/double click to get the crash ... and does that happen on built-in materials or also on self created materials as well as does that happen with drawings, which had materials from older AutoCAD releases.
A good test would be to create a new drawing (using an AutoCAD original template) and try the same procedure so we know that nothing comes up from old releases.
One general question: when you started AutoCAD 2016 the first time did you migrate the settings from your prev. AutoCAD release?
- alfred -
Alfred NESWADBA
www.ish-solutions.at ...
blog.ish-solutions.at ...
LinkedIn ...
CDay 2025------------------------------------------------------------------------------------
(not an Autodesk consultant)
