FATAL ERROR: Unhandled e0434352h Exception at 8469a839h
tfarms2
Observer Observer
tfarms2
Observer
Observer
Any time I attempt to open the application, it barely runs and then aborts to this message.
I started out with AutoCAD 2020 and it gave the same error, I've reinstalled and I've also tried older versions of AutoCAD but I still get the same message.  I also uninstalled and reinstalled the Windows C++  redistributables as well.
I'm running Windows 10, and I used to be able to run this program without any issues.
S.Faris
tfarms2
Observer
Observer
I tried both of those links and did what they said, but the error still shows and the program never opens
Any other suggestions?
S.Faris
Autocad is crashing while opening a drawing file or even while working on a brand new empty drawing file? Can you explain the event a bit more
Which version of autocad is it?(post a screenshot of the ABOUT command result window)
Have you updated your Autocad tot he latest version?
SALMANUL FARIS
S.Faris
tfarms2
Observer
Observer
AutoCAD crashes within seconds of opening any file, new or a previously saved file. The large loading box opens, but within about 2 seconds it crashes and then the error message shows.
As far as the version, I can't open the ABOUT window since I can't even access the program, but I've tried AutoCAD 2017, and then updated to 2020 and both versions have had the exact same issue. It should be the latest version. (I apologize for taking so long, I've been crazy busy!)
tfarms2
Observer
Observer
Here's exactly what I see.
