FATAL ERROR: unhandled e0434352h Exception at 2da63fb8h
davidmotzen
davidmotzen
please help me with my error
0 Me gusta
Responder
328 Vistas
2 Respuestas
Respuestas (2)
J.FOCHT
Hello @davidmotzen,
Sorry to hear that you received that error. I would suggest checking your graphics card. Please make sure that your graphics card can handle what Autocad is throwing at it. I would also check your drivers and make sure that you have installed and are running the latest driver for your graphics card. It could also be a corrupt file. If that happens you will want to AUDIT and RECOVER the drawing file. Another option would be to uninstall and reinstall the .NET framework. A link on how to do that step is provided below.
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/sfdcarticles/sfdcarticles/How-to-r...
I hope you get everything back up and running soon!
If this helps you then hit the LIKE button or mark as an ACCEPTED SOLUTION!
Thank You!
Jonathan Focht
0 Me gusta
imadHabash
This kind of error may cause by many reasons, but you can try one of the follow :
  • try to launch your autocad as administrator from new windows account .
  • Disable Antivirus & Firewall for a while and see if any changes.
  • it's recommend to clean your  Temp folder ( C:\Users\your user name\AppData\Local\Temp )
  • reset autocad to default settings . >> Click <<
Imad Habash
