FATAL ERROR : Unhandled Access Violation Reading 0x0000 in AutoCAD 2014
I am having a similar error. I am a student running AutoCAD 2014 on Windows XP. I am using a student version. I get about three minutes into my work and the program crashes. I don't even have to do anything other than start the program. Wait a few minutes then I get the error.
FATAL ERROR: Unhandled Access Violation Reading 0x0028 Exception at 2e444b6bh
Please help!
Note: This thread was split from another one in the AutoCAD forum
john.vellek
HI @Anonymous,
I see that you are visiting as a new member to the AutoCAD forum. Welcome to the Autodesk Community!
I'm sorry to hear that you are having this error when running AutoCAD 2014. Please verify that your Windows XP has service pack 3 applied as well as any subsequent updates.
Then, please try running your AutoCAD with the No Hardware switch. If it behaves that means you have a graphics card issue. You should check to see if you have the most current driver.
Please tell me what card you have installed.
John Vellek
I am now running AutoCAD with the no hardware switch, it has not crashed since. Thanks!
I am using a Dell Optiplex GX 620 with Windows XP SP3. All updates are current.
My graphics hardward is onboard. Below are the details of my graphics hardware:
Name Intel(R) 82945G Express Chipset Family
PNP Device ID PCI\VEN_8086&DEV_2772&SUBSYS_01AD1028&REV_02\3&172E68DD&0&10
Adapter Type Intel(R) 82945G Express Chipset Family, Intel Corporation compatible
Adapter Description Intel(R) 82945G Express Chipset Family
Adapter RAM 224.00 MB (234,881,024 bytes)
Installed Drivers ialmrnt5.dll
Driver Version 6.14.10.4410
INF File oem37.inf (i945G0 section)
Color Planes 1
Color Table Entries 4294967296
Resolution 1280 x 768 x 60 hertz
Bits/Pixel 32
Memory Address 0xFEB00000-0xFEB7FFFF
I/O Port 0x0000E898-0x0000E89F
Memory Address 0xE0000000-0xEFFFFFFF
Memory Address 0xFEAC0000-0xFEAFFFFF
IRQ Channel IRQ 16
I/O Port 0x000003B0-0x000003BB
I/O Port 0x000003C0-0x000003DF
Memory Address 0xA0000-0xBFFFF
Driver c:\windows\system32\drivers\ialmnt5.sys (6.14.10.4410, 1.24 MB (1,302,812 bytes), 3/19/2009 17:07)
PNP Device ID PCI\VEN_8086&DEV_2776&SUBSYS_01AD1028&REV_02\3&172E68DD&0&11
INF File oem37.inf (i945G1 section)
Color Planes Not Available
Color Table Entries Not Available
Resolution Not Available
Bits/Pixel Not Available
Memory Address 0xFEB80000-0xFEBFFFFF
sfreemancad
I have a similar issue today with one of my drawings. The error reads "FATAL ERROR: Unhanled access violation reading 0x0000 exception at d452a3e3h" and my civil 3d just crashes every time i open it and it was fine yesterday. I am running win7 and using civil 3d 17
sfreemancad
I have the same problem with the Fatal Error:  Unhanled access violation reading 0x0000, did you find any solution?
