Fatal Error AUTOCAD 2015
No aplicable
Hi There,
I have some problem with my AUTOCAD 2015. Suddenly some error apear when i try to open AUTOCAD
Can someone help me with my problem?
0 Me gusta
Responder
3.027 Vistas
12 Respuestas
Respuestas (12)
imadHabash
there are many reasons that cause such a problem. i suggest to read and follow here these solutions that it may help. >> Click <<
Imad Habash
No aplicable
Hi Imad,
Referring to your links, and i found like this :
Solution:
There are several ways to troubleshoot the problem:
I have already update all software requirment via Autodesk Application Manager, but all the issue seems not solved.
Already opening any file .dwg. But the error keep showing
  • Uninstall any antivirus or desktop locking programs.
    These programs can cause errors in AutoCAD, since they prevent the system environment from working.
No single antivirus installed on this PC, i already uninstall it
Done Resetting, but still error
My PC use the lastest driver
Already try that too, but no effect at all. Still error
  • If DisplayLink Core software is installed on your system, try uninstalling it.
No DisplayLink Core software installed
Already try this too, but error still appear
  • Clear the digital signature icons and then uninstall and reinstall the application.
            See:   FATAL ERROR: Unhandled Access Violation Reading 0x0000 Exception at 4048b9h
  • Configure Internet Explorer as the default browser and remove all check marks from the LAN Setting option.​
  1. Open Internet Explorer.
  2. Click Tools > Options.
  3. Access the "Connections" Tab.
  4. Click "Lan Settings."
  5. The settings should look like this:
Lan Settings
0 Me gusta
imadHabash
if you launch autocad from a new user account ... any changes ? or / and launch it as admin (Run as Administrator ).
Imad Habash
0 Me gusta
No aplicable
No affect at all, the error still same. Just now i figure it out some update avaible in Autodesk Manager. I download it, and then the error code change like this :
But after i click OK button, AutoCAD will suddently closed, just like previous error code
0 Me gusta
Alexander.Rivilis
Try to disable Windows Firewall. Similar problem was solved: https://forums.autodesk.com/t5/autocad-forum/fatal-error-unhandled-error-c0000006h-in-autocad-2017/t...
Відповідь корисна? Клікніть на "ВПОДОБАЙКУ" цім повідомленням! | Do you find the posts helpful? "LIKE" these posts!
Находите сообщения полезными? Поставьте "НРАВИТСЯ" этим сообщениям!
На ваше запитання відповіли? Натисніть кнопку "ПРИЙНЯТИ РІШЕННЯ" | Have your question been answered successfully? Click "ACCEPT SOLUTION" button.
На ваш вопрос успешно ответили? Нажмите кнопку "УТВЕРДИТЬ РЕШЕНИЕ"
Alexander Rivilis / Александр Ривилис / Олександр Рівіліс
Programmer & Teacher & Helper / Программист - Учитель - Помощник / Програміст - вчитель - помічник
Facebook | Twitter | LinkedIn
Expert Elite Member
0 Me gusta
Alfred.NESWADBA
what happens when you disconnect your workstation from network and then start AutoCAD?
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
0 Me gusta
pendean
Community Legend
Community Legend
0 Me gusta
No aplicable
Done, but still no effect. Same Error Code still appear
0 Me gusta
No aplicable
Hi Alfred,
The error message still appear, but the code seem changes
0 Me gusta
No aplicable
Hi @pendean,
I follow your instruction, but my OS not avaible on there. I using Win 8 Pro
0 Me gusta
ennujozlagam
@Anonymous hello, try to repair or reinstall program it could be some files are corrupted. thanks
0 Me gusta
Alfred.NESWADBA
does your system have Framework 4.7 installed? If so uninstall it and install version 4.5 or 4.6.2 instead.
- alfred -
Alfred NESWADBA
0 Me gusta
