Failed to create object. Make sure the object is entered in the system registry
Message 1 of 19
Hi all
I followed the instructions on the link below:
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/error-...
Solution:
To resolve the error, delete the main registry path for AutoCAD and then run a reinstall of the program:
  1. Press WINDOWS-R on the keyboard to bring up the Run window, enter REGEDIT and click OK.
  2. Navigate to the following:
    HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\Rxx.x
    Note: The "Rxx.x" folder can contain registry entries for multiple versions of AutoCAD. If you have more than one AutoCAD of the same release installed, a reinstall will be needed on each.
  3. Delete the "Rxx.x" folder.
  4. Close the Registry Editor and then open Programs and Features.
  5. Double-click AutoCAD and do a reinstall of the program.
Warning!
Problems caused by improperly editing the Windows registry could render your computer operating system unusable. Microsoft provides a wealth of critical information that you need to know about the registry in the Microsoft Knowledge Base. Use the Microsoft Registry Editor only at your own risk and only after backing up the registry as outlined for your operating system in the Microsoft article How to back up and restore the registry in Windows and in the related solution How to backup the system registry. Additional information about the registry is also contained in the Help topics in the Microsoft Registry Editor.
As a workaround to the error, it may be possible to create a new OLE object instead of inserting one from a file. When the linked application starts up, copy-paste the content into it and then close the program. As a secondary alternative, attach the file as an external reference instead of embedding it into the drawing with OLE.
As stupid as I am... I ignored the Warning sign and deleted the folder and now my AutoCAD won't start up.... Please help! I have a student version so I am sure how I can re install my program....
Replies (18)
Message 2 of 19
S.Faris
Before going for a re-install try Resetting : To Reset the Application to the Default Settings
SALMANUL FARIS
Message 3 of 19
S.Faris
If resetting fails, here is the Recommended uninstall and reinstall procedures
 Recommended uninstall and reinstall procedures for AutoCAD
SALMANUL FARIS
Message 4 of 19
Thank you for sending that information but unfortunately, the instructions were not clear and I could not do either.... Do you know if it is possible to repair a student version? I may not have permission..
Message 5 of 19
S.Faris
What you mean by, You might not have permission?.
Instruction was
  • Click on the Windows Start Icon
  • Type Reset and select the Reset settings to Default.
Which part of this is not clear?
SALMANUL FARIS
Message 6 of 19
S.Faris
Repair Installation Screencast
Repair Install
SALMANUL FARIS
Message 7 of 19
I have done exactly that but not happens after I type in click "Reset Settings to Default" in the windows start
Message 8 of 19
S.Faris
here is a screencast for the Reset :
SALMANUL FARIS
Message 9 of 19
New message:
AutoCAD Error Aboring:
FATAL ERROR: Unhandled 00434352h Exception at 9eda388h
Message 10 of 19
S.Faris
Did you Repair the Autocad?
or did you try Resetting the Autocad?
SALMANUL FARIS
Message 11 of 19
I tired to repair
Message 12 of 19
S.Faris
Was the repair successful? did you try opening Autocad after that? What was the result?
SALMANUL FARIS
Message 13 of 19
It was successful but when I got to open it, a new message comes up -
Message 14 of 19
S.Faris
Ok. Then try resetting the settings as shown in the screencast
SALMANUL FARIS
Message 15 of 19
Ok...I just did that and it still shows the same error message...
...I don't understand why it is doing this..
Message 16 of 19
S.Faris
Maybe you should update your Autocad : Update Software in Autodesk Account
SALMANUL FARIS
Message 17 of 19
I had to re-install the software last night. It works like normal now thanks for all your help though 🙂
Now, I have to figure out why I can't insert my excel sheet...
Error message now:
Failed to create object. Make sure the object is entered in the system registry... You wouldn't be able to help me there could you?
Message 18 of 19
cheryl.buck
Autodesk Support
Autodesk Support
Hi @Anonymous,
I just saw your post. I hope you were able to resolve this, but wanted to post the Autodesk Knowledge Network (AKN) article for the warning you were seeing in hopes it will help others.
"Failed to create object. Make sure that the object is entered in the system." inserting image as an...
All the best,
Cheryl Buck
Technical Support Specialist
Did a post answer your question or help resolve the issue? Please click the Accept Solution button.
If you find a response helpful, consider Liking the post.
Message 19 of 19
Sahlbuhary
Thanks you
