Factor in Xref
Factor in Xref
16144057
Factor in Xref
16144057
Hi All. I have proplem. When i use Xref for my draw, I can't edit "Factor" (Factor = 1 is normal)  then  my draw is not to Scale. How can i fix it?
Accepted solutions (3)
ennujozlagam
what is xref dwg units? have you try to change your dwg units and see if helps.
3wood
Please use command UNITS to set "Insertion Scale" to "Unitless" or "Millimeters". At moment, it is set to "Inches" in your AutoCAD.
Valentin_CAD
@16144057 ,
These links provide  more information:
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
Thanks for your help, i fixe
