Facing problems with opening a DWG file
No aplicable
Dear all,
I would like to open a DWG file. But, it has shown like what the image is showing now. So, could anyone tell me how to open those files without affecting its originality?
Best Regards,
0 Me gusta
Responder
383 Vistas
5 Respuestas
Respuestas (5)
S.Faris
The Meaning of the Pop up is, You have some XREFs in the drawing which is missing. (CHECK THIS)
SALMANUL FARIS
0 Me gusta
ennujozlagam
Some xref's file are not in the same folder when it was loaded. thanks
0 Me gusta
ian.mag
Hey,
To add on what has been said in the above comments, i would suggest you "Open the External References Pallete" while opening the drawing. In the XREF pallete you shall see all the drawing attached to the dwg file. You can then locate the file path for the XREFS attached in the drawing under the "Details>Found at/Saved path".
You may alternatively "ignore the unresolved reference files", to open you drawing but that would mean that the drawing cant really located the path for the xrefs in your computer.
0 Me gusta
BrianBenton
I'm not sure what you really want to do. The error, as stated by others, tells you that CAD can not find the referenced files. If you need them to reference properly you will have to open the reference manager from within the file and re-path the referenced files.
Brian C. Benton
bbenton@cad-a-blog.com
http://CAD-a-Blog.com
twitter.com/bcbenton
www.facebook.com/CADaBlog
0 Me gusta
s.borello
Did someone send you this file? If you don't have the xref files, you will need to request them from whomever sent you the file.
0 Me gusta
