Facing error while file opening
No aplicable
I am facing a problem while during a file open.
Error is " there was a problem sending the command to the programme."
0 Me gusta
Responder
271 Vistas
3 Respuestas
Respuestas (3)
imadHabash
it sound that this is a Double-Click trouble .... When double-clicking a DWG file in Windows Explorer, AutoCAD is launched or brought to the front but the drawing file is not opened and that message appears. i suggest to follow this AKN article that it may help.
Good Luck..
Imad Habash
0 Me gusta
john.vellek
HI @Anonymous,
It is possible that the user profile is damaged.  But, I first suggest that you check user permissions to make sure they are not too restricted. Then, rt-click a DWG file and re-associate it with DWG Launcher.
Also, make sure that the file itself or the folder that contains it is not set to read-only.
Can you open a file if you do so through the program rather than Windows explorer?
If none of this works, try creating a new user account (administrator permissions) and log on to see if you can then run AutoCAD properly.
John Vellek
0 Me gusta
john.vellek
Hi @Anonymous,
I am checking back to see if my post or Imad helped you with your problem. Please add a post with how you decide to proceed and your results so other Community members may benefit.
Please hit the Accept as Solution button if a post or posts solves your issue or answers your question.
John Vellek
0 Me gusta
