Extruding/Presspulling not making 3d object
Message 1 of 9
 I wanted to make an object I drew into a 3D model. But presspull is not working and extruding is only extruding the boundary lines. Please help.
Replies (8)
Message 2 of 9
Patchy
Expand the command line for more than 1 line, look for MO (Mode) option.
Message 3 of 9
Hi, I'm still relatively new. Can you explain how to do that?
Message 4 of 9
Patchy
Hold down the Ctrl key, move your cursor to the edge of the command line and pull it up so you can see more than 1 line.
After picking the Extrude or Press/Pull command there should be a MO option, use Solid (not Surface )
I don't use new autocad at this moment so I can't send you a snapshot of it.
Message 5 of 9
imadHabash
Hi and Welcome to AutoDesk Forum,
I suggest when you use PressPull command and AutoCAD ask for Select object or bounded area select the area between the lines that you want to extrude don't select the line itself because you will get another result.
Imad Habash
Message 6 of 9
I am doing exactly as you are saying, clicking between the lines.
Message 7 of 9
Patchy
Attach your drawing, let's test it.
Message 8 of 9
imadHabash
draw Rectangle from Rec command and use PressPull command and tell us a bout the result. and please attache your drawing here to test it in our systems.
Imad Habash
Message 9 of 9
Ah, guys, I got it. I redrew the object with a polyline and this time presspull worked.
Thank you, everyone for helping!
