Extrude only edges of polyline not full solid
Message 1 of 8
I did a special shape with arcs and lines, I then join them to make one polyline which worked and now I'm trying to extrude it so that I can have a 3d solid of that shape but it only extrude the edges, the solid is empty inside. I made sure that every arc and line were connected from endpoint to endpoint and I checked again to make sure there were so mistake so I don't understand why it's not working. If someone could help me please, I've been trying to figure it out for a few days now...
Replies (7)
Message 2 of 8
sophia_lee
Hi @Anonymous,
Have you used REGION or BOUNDARY command to create a new shape and extrude it?
If above is not working, could you post the sample drawing here?
Thank you,
Please 'Accept as Solution' if this helps.
Sophia, Lee
Sr Technical Support Specialist
Customer Technical Success APAC
Message 3 of 8
cynthia.claire.tan
Hello @Anonymous ,
Welcome to AutoCAD Forum! I understand you are trying to extrude your model. There are a few suggestions in this other forum post which may help: https://forums.autodesk.com/t5/autocad-forum/polyline-extruded-is-quot-empty-quot/td-p/7583808
If none of this worked, let me know. If you could provide the drawing file that would be helpful. Hope this helps! 🙂
If my reply was helpful, please like or click the "Accept as Solution" button below (or both).
Cynthia Claire Tan
Global Product Support
Message 4 of 8
Hi, when I click on your link it goes on my question, but here's the drawing in Autocad 2019
Message 5 of 8
cynthia.claire.tan
Hi @Anonymous , sorry about that. Here's the correct link: https://forums.autodesk.com/t5/autocad-forum/polyline-extruded-is-quot-empty-quot/td-p/7583808 🙂
Cynthia Claire Tan
Message 6 of 8
vinodkl
Try to flatten the object using the command "FLATTEN" and then join the object to make it close. Now use the command "EXTRUDE" or "PRESSPULL"
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Message 7 of 8
Hi Cynthia, I tried all the solutions in the link you sent but none are working. It's weird because when I do boundary a duplicate of my drawing appear but if I do enter, the duplicate disappears.
Message 8 of 8
THANK YOU SO MUCH IT WORKED OMG. Once I flatten my drawing on Top view it removed the part that wasn't flatten so I redid it, I join and I extruded and it worked! You saved me a lot of times. Really appreciate. 😄
