Extrude - object removed from selection set
Message 1 of 10
SO I am having this problem that I cannot extrude petals of this flower. I created 1 of the petal into polyline (blue one) and it still gives me "object removed from selection set". Where could this problem be?
Replies (9)
Message 2 of 10
Alfred.NESWADBA
That is not all you get ... 😉
In most cases I have trouble with _EXTRUDE I try command _PRESSPULL if that can work with that geometry.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Message 3 of 10
Yes, when I presspull, I get cannot extrude self interacting curve...
How do I fix this? 😞
Message 4 of 10
parkr4st
moved the radial lines to a new layer  RadialLines and hid it; set new layer to petals and used bpoly command.   only one of your petals is closed and made a new petal.  that will extrude fine.
it is in the attached drawing
you can extrude and arraypolar that item
there is/are problem(s) in the original line work someplace.
dave
Message 5 of 10
But that pink petal extrudes only in net form for me, as if it wasnt closed boundary
Message 6 of 10
parkr4st
EXTRUDE, MOde  set to solid?
Message 7 of 10
Ok, I have managed to extrude this one petal here, hut now I am having problems creating surface according to these pink splines... I need to create surface before using polar array... Any ideas?
I tried using networksrf command, but it requires two directions. Any ideas how I can define these two directions to make surface?
Message 8 of 10
parkr4st
one way
draw arcs at each end of the petal and loft those with the center profile you provided.  More cross sections can provide more detail.
dave
Message 9 of 10
parkr4st
use this dwg, the other didn't save correctly:(
Message 10 of 10
"with the center profile you provided" you mean that only cross section of  two purple splines? 🙂 I see, i need to create more boundaries(arcs/splines) of this surface, for it to fit to the frame, correct? 🙂
