Extrude arraypolar
Extrude arraypolar
saitoib
Extrude arraypolar
saitoib
Hi all.
Is it possible to draw a circle and then use the arraypolar command to extrude the arrayed shapes in 3D?
Thank you.
Saitoib
Valentin_CAD
@saitoib ,
Read about 3DARRAY (Command).
Select the "Mark as Solution" if my post solves your issue or answers your question.
Seleccione "Marcar como solución" si mi publicación resuelve o responde a su pregunta.
Emilio Valentin
AVCPlugins
First: extrude the solid. Second: make the array.
Plugins for AutoCAD
A>V>C>
AppStore | Facebook | Twitter | YouTube | Blog
saitoib
@Valentin_CAD
@AVCPlugins
As I thought, arraypolarized shapes and block shapes cannot be extruded as is.
Thank you very much.
Saitoib
Kent1Cooper
Or, make it a non-associative array [whether inside the current ARRAY command or with ARRAYCLASSIC], or ARRAY it and then Explode the Array, and then you have the option to Extrude only some of the objects, or Extrude them to varying degrees, etc.
Kent Cooper, AIA
